Whenever I take a shower my toilet has air bubbles.
Do I need to snake my plumbing?
I live in a mobile home so do I remove the toilet to snake the main line or what do I need to do and how?
    Do NOT remove the toilet to snake. I believe there are standards for mobile homes which would specify that they be constructed with a cleanout under the unit. I suppose it has a vent out the roof. First try running some water from a hose down the vent and see if this clears the vent. – Jim Stewart Mar 10 '18 at 4:28
  • The air bubbles in the toilet are from passing gas in the shower. :-) – fixer1234 Jul 17 '18 at 20:05
Sounds to me like a roof vent is plugged or restricted. Run water from a hose into each roof vent and see if you can clear them. Have someone inside while running water into the vents to insure that if this would cause a water leak inside that you stop before doing damage.
Or run a snake down each roof vent. But don't drive the snake into the drain joint where the vent connects to the horizontal runs. You could damage the drain and turn a minor problem into a major one.
| improve this answer | |
