I have one question for whoever might know a thing or two about sound insulation. I will install a stud wall over the existing brick party wall for sound proofing purposes.
Currently we have laminate flooring over the old floor boards, is it ok to install a stud wall over the laminate, leaving 1cm gap at the bottom for the acoustic sealant, or should I cut the portion of laminate beneath and go with the studs down to the floor boards?
