I want to update the lights in my kitchen with pendant lights. enter image description here
However, for one light, the current light has a loop over to a hook to hang the light in the appropriate spot. Like this.... enter image description here
I want to use the current holes in the ceiling for this - but how do I - can I loop/move this over to hang in the appropriate spot? How do I support/hang the light from the desired location?
Any help is appreciated!
  • Are you ok with having a blank cover over the current electric box and installing a new box in the desired location? – JPhi1618 Feb 28 '18 at 14:45
  • you could cut the cord on the old one after the hook and tie it into the new one's wires, after you cut off it's base part; a mashup. – dandavis Feb 28 '18 at 16:10
The new lights will mount to the boxes that are under the pendent light box covers. You can remove the hook eye and patch the hole.
Moving a light over 8 inches will make almost no difference in the light pattern.
It appears the original light needed some support besides the box so they install the hook and loop.
Good Luck!
| improve this answer | |
    8 inches may not make a difference in the light pattern, but if it is over a table it will make the difference between center-of-the-table and guests-banging-their-heads-on-every-time – Jeffrey Feb 28 '18 at 21:50
  • I would agree with the center of the table part. If 8" off center means you are now banging your head you have a pretty small table there. – ArchonOSX Mar 1 '18 at 11:55
