I have seen this done but never knew HOW it was done and remained in place. I am planning to gravel my sand driveway within the next month or so but in the meantime, I'm thinking about buying a heavy duty tarp to cover the sand (it's driving me crazy!) I was told to get cinder blocks to hold it in place but was wondering if there was a less conspicuous way to keep the tarp from blowing around (a huge blue or green tarp in the front yard is already ugly enough!). Also, recommendations on the type/brand of tarp would be helpful, as well! Thank you in advance for your help!!
wrap some 2x4 lumber into the edges, so it acts as a frame – jsotola Feb 20 '18 at 19:22
@jsotola now that could work...means I would have to get much larger tarp, though, which depending on cost of 2 of 2x4's and how many I need, could get a bit costly for temp fix. But thank you, I'll keep this idea in mind! – mspatient10 Feb 20 '18 at 19:26
Do you want to use a tarp? Water will hold in the low spots. – Ed Beal Feb 20 '18 at 19:39
I'm not sure the tarp is a good idea to begin with. As you drive, the sand will move and the tarp will develop loose areas. Eventually they'll be snagging on the vehicle. Instead of asking how to hold down a tarp, ask how to resolve your actual problem (which hasn't been made clear). – isherwood Feb 20 '18 at 19:43
@EdBeal I thought about that...I'm open to suggestions! Again, it's temporary, only about a month or so...but I'm definitely open to ALL suggestions! – mspatient10 Feb 20 '18 at 19:44
Show 3 more comments
Maybe drive them in at opposing angles... I've used these for holding down weed-cloth (what they are really made for), and they didn't seem to have a lot of grip. – JPhi1618 Feb 20 '18 at 20:12
@JPhi1618 Is weed cloth tougher than tarp? Do you think it will go through and hold the tarp? Or was the problem that they tore through cloth? – mspatient10 Feb 20 '18 at 20:39
Weed cloth is lighter, and it's not that they tore through - the thin wire didn't seem to grip the soil very well. It's a great suggestion, and cheap to try, but results are going to depend on your soil. They won't rip through the tarp. – JPhi1618 Feb 20 '18 at 20:41
