When replacing door trim the wallboard PAPER came off! how do I repair this 6’ x 1’ strip along side door frame? Do I joint compound plaster?
    Did you intend to include a photo? You'll need to host it elsewhere until you have a bit of reputation.
    Commented Feb 20, 2018 at 15:34
Without seeing the damage, it usually involves skimming with joint compound, sanding lightly, priming and painting. Trim away any loose material first.
