I have this corner sink that I would like to install.
Holes location on sink :
I have moderate DIY skill and have previously installed a bidet that needed water hose T joint. So I think I can pull this one off.
There is existing water pipe for toilet and floor drain outlet-
T joint location for water connection:
Drain /grate connection:
The house plumbing type is pressurized , there is a main water valve that can be used to shut off water from the mains.
I could think of following parts :
- Strainer Basket
- 2x Double headed coach screw ?
Saw them here at 4:00
youtube.com/watch?v=SrUdoKQukZw
Like this -
Any sealant ?
Water pipe T-joint
Any thing else I am missing? Any other tips to get this DIY job done would be great.
Thanks in advance
