Please help. I'm trying to replace an outlet. The one I'm talking off is a two prong outlet and the bottom is switched. There is no ground, there is a white, a black, and a red. I think I'm right that it's a line outlet, right? I'm trying to put in a GFCI and I don't know where to put the red. I hope that's clear enough. Thanks in advance!
There are three wires coming into your old configuration:
  • neutral
  • always-hot (used on the always-on half of the receptacle)
  • switched-hot (used on the switched half of the receptacle)
Code says that if neutral is present (it is), then it must be white. So the white ought to be neutral. Code does not mandate the other two be any particular color. Either could be either one, but some electricians like to use black for always-hot and red for switched, in a case like this.
Your GFCI+receptacle combo device requires two wires:
  • neutral
  • always-hot
As you can see, the switched-hot wire is useless. Cap it off with a wire nut, then tape the wire nut on so it doesn't come off. Do not cut the wire back, you cannot insulate it if you do, and the next owner may want to use it.
The red is probably the switched leg which went to the bottom of the old outlet.
Just cap it off safely with a wire nut and leave it.
Since you don't have a ground wire on your new GFCI, you should label it "No Equipment Ground" (and your new GFCI probably came with some pre-printed labels for that).
  • Perfect. That's what I thought the red was. I think your right about the labels and I'll do as you've suggested, but I'm curious, if I had put the red and black together, would that produce 240V?
    – Gilmore
    Feb 18 '18 at 0:05
    It's theoretically possible, but very, very unlikely that the red switched-hot and black always-hot would have been wired on different phases. So probably not.
    – brhans
    Feb 18 '18 at 0:21
  • Good to know. So I got the white and black wired on the line side and the outlet is (still) switched. Does that mean the black is the switched and the red is constant hot and I should just switch them and tuck the black out of the way?
    – Gilmore
    Feb 18 '18 at 0:29
  • Yes, exactly that.
    – brhans
    Feb 18 '18 at 0:48
