I have couple of questions to the experts. I see copper stains (green/blue) in my sinks and at shower tubs. I had comprehensive water analysis done. Water was sampled from tap after flushing. My water is soft with pH 6.65. I am on well water. Below are the levels of some elements:
- Hardness (calc.)->50.5 mg.CalCO3/L
- Calcium-> 16.0 mg/L
- Magnesium-> 2.56 mg/L
- Sodium-> 10.0 mg/mL
- Copper-> 0.221 mg/L
- pH 6.65
Assuming that stain is coming from copper pipes, I called a company which installs filters.
The company told me that amount of stain is too much for the level of pH. I am not sure what to make of it. Could there be any other reason besides low pH to corrode my copper pipes. My house is 27 years old. I only had it for 3 years. And this house never had filtration system before.
The company proposed that I install neutralizer to bring pH to 7.0. This part makes sense to me and requires installation of a tank (tank #1). However, they want to install a water softener to remove neutralizer (Calcite) from water to make it soft again (tank #2). To regenerate softener matrix, they need a third tank (tank #3) for backwashing that uses salt for regeneration. Their calculation is that I (two people) would use ~500 pounds of salt per year for regeneration process. I personally think that it is a waste, and not an environmentally friendly method.
Moreover, my google search tells me that there many companies suggesting that if my water pH is above 6.0, I should only need neutralizer, not additional softerner/baskwashing tanks.
I am wondering if anyone has comments on this. Thank you very much.
