I have partially assembled a tree bookcase and have discovered that I have been supplied with an incorrect part. I was supplied with the part shown in the attached picture. The pictured part is 76mm in length, yet the assembly requires the same but at 71mm. I have contacted the vendor, who do not know the part's name, but assure me that I can find them in any hardware store. No hardware store I have visited has been able to identify it, though.
Please, can somebody tell me what is the name of the part, and where can I find one that at 71mm?
Thanks.
    1. What does it connect to? That'll help in identifying/naming it. 2. Are you sure you need a shorter one? Do you think you need 71mm because the instructions say so? - It could be a misprint. Or because you can't make it fit properly? - Maybe you're assembling it wrong.
    – AndyT
    Feb 15, 2018 at 10:54
  • It is used to join the top (heavy) half of a bookcase to its bottom. The two pieces are to be joined end to end. The instructions state that a 71mm connector is required. Inserting the connector reveals that it is 5mm away from sitting flush.
    – Adam
    Feb 15, 2018 at 10:57
  • Sorry, I wasn't clear enough. Rather than what it connects (two parts of a bookcase), I want to know what other components it connects to. i.e. Does it connect to a cam at both ends? Something else?
    – AndyT
    Feb 15, 2018 at 11:03
  • My fault, entirely! And yes, it connects to a cam. I believe that the shorter one might work, so I'll give it a try. Thanks again
    – Adam
    Feb 15, 2018 at 11:21
  • what do the assembly instructions call it?
    – jsotola
    Feb 15, 2018 at 17:54
I'm tempted to call that a double-ended dowel for a cam connection.
  • Thank you. It seems that they're readily available...in 68mm.
    – Adam
    Feb 15, 2018 at 11:02
  • That's frustrating! Maybe you could use the shorter one, and re-drill the hole for the cam? It wouldn't be as strong though, as the original hole will mostly overlap with the new hole. And it would look a bit bodged too, if it was visible.
    – AndyT
    Feb 15, 2018 at 11:06
  • If the one that's 5 mm too long isn't close enough, 2 mm too short isn't likely to work either. Recutting the hole 2 mm shallower is likely to be a lot weaker; I'd feel safer with the too-long piece and a spacer -- or a web search for the elusive 71 mm part.
    – Steve
    Feb 15, 2018 at 16:08
