We are in the planning stages for a 40x40 detached garage / shop I am building and need to know what will be required in Everett, WA 98204 to bring power to the building.
- First off, I will need to run a high powered arc welder that currently is running off a 40A dual-pole breaker so that if I need to crank it up to its highest setting, I wouldn't have issues with the breaker popping when making long welds.
- The new shop will also have a dual stack oven that you normally find in a kitchen that we use for powder coating parts.
- Plus I want extra power available so if the oven is on, someone is welding, and someone else turns on the shop vac and all the lights, I am not popping breakers.
- I also plan to add even larger machine shop type equipment with time, like CNC machine, lathe, and mill (that's hopefully not going to require 3 phase).
I read other articles that say tie into the house breaker, which is only a 200A panel. I added up all the existing breakers as-is, which come to more than 200 amps. But I do not really know how much power would actually be drawn on each circuit if everything in the house was to be turned on, appliance and heat wise (all lights are already LED to conserve power, and heaters are all 220v in each bedroom).
For example, the kitchen lights are only a handful of LED bulbs and outlets with no real power being drawn, but has a 20A breaker. Same goes for nearly every circuit off that panel. So I am probably sure I could run a sub panel off it.
But let's say there are 4 roommates in the house running every appliance, plus 3 people in the shop doing the same. I don't know if that would equal more than 200 amps. But the last thing I want to do is risk it.
So my questions are:
- Can I run conduit off my meter on the outside of the house, instead of the existing house panel, and install another 150-200A panel 60' away in my shop?
- I would like the ability, over time, to add a bunch of machine shop equipment like CNC machine, lathe, mill, and etc without having to do all new electrical service to the shop again 2-3 years later. What should I do to not have future issues?
- Will conduit off the meter work instead of the house panel? If so what size conduit and cable to the new shop panel?
