I have a detached garage with fairly large sliding windows (previous owner installed these) with a brick exterior. I want to remove the windows and close up the wall with bricks. What do I need to do to accomplish this? Will I need to remove some of the brick surrounding the windows? I expect I need to be able to put up some exterior wall material plus some moisture barrier. I'm new to DIY home improvement so any input would be appreciated. Thanks.
Tom
