I have a stub-out for my bathroom which exits the wall at a 45 degree angle (roughly). The trap used to be in a vanity, but it's now exposed. Is there such a thing as an escutcheon that will fit at an angle?
  • a picture would help
    – jsotola
    Feb 7 '18 at 18:49
  • For the 1/2" water pipes or for the drain (size?) ? Is it possible for them to exit the wall perpendicular and then bend 45 degrees once out of the wall?
    – JPhi1618
    Feb 7 '18 at 20:44
I have seen escutcheons shaped like this but don’t know where to buy.
It is possible you could modify one to accommodate the angle. Make the inner circle into an oval.
  • Why would an oval ?
    Jul 14 '18 at 14:55
  • @EdBeal, because a diagonal cross section of a cylinder has an oval shape.
    – fixer1234
    Jul 14 '18 at 21:44
