Its 2/5/20118 now and my septic pump on a brand new gfci trips the gfci---the new float switch does not by itself trip the gfci--the pump by it self or in combo with the flooat switch does trip--I checked continuity black to ground no white to ground no black to white--YEA shows continuity--I find that curious!
I checked all 4 of my new gfci (o0nly one dedicated on a single circuit to the sump pump) and they are all working fine--except when I plug the pump in to the dedicated gfci on a single breaker/ciRcuit----any suggestions?
  • I checked continuity ... how did you check it?
    – jsotola
    Feb 6 '18 at 3:19
    The pump has a ground fault. Its leaking electricity somewhere.
    – Tyson
    Feb 6 '18 at 3:49
  • I thought it was recommended not to use a GFI for a sump pump, but I'm not sure.
    – Dotes
    Feb 6 '18 at 22:19
  • GFCI are notorious for tripping on the surge of an electric motor. Is the GFCI an outlet or a circuit breaker?
    – Skinner
    Feb 9 '18 at 16:07
