I moved into a house I’m renting a few months back. I’m allowed to drill holes in the walls so long as I cover them before I move out...
So I’ve marked the studs, I drill, and there’s nothing behind the drywall. I’m no expert, but I’m a little confused as to how I’ve found a stud and there’s no stud. Could the drywall be extended?
In case you’re thinking I’m stupid (though I’m not saying I’m not! Haha), here’s a little more explaination of what I’ve done:
  • Found stud with Franklin Sensors Prosensor 710
  • Confirmed by sound (knocking on wall) after drilling and not finding a stud
  • Confirmed with magnetic stud finder
  • Still confused, used a piece of wire to check depth - there’s something in the way of the wire 4 and 1/4 inch deep, nothing in the way left or right of where the stud apparently is.
I don’t want to go cutting huge holes in the wall to figure out what’s behind them unless I have to. Could the drywall be extended out for some reason? These are the walls around the foundation of the basement.
Thanks!
Simply put...you missed the stud location when you made the hole.
You could try using a wire in the wall up, down, right and left from your hole to locate the actual stud location.
Note that stud locators and never deterministic for every situation.
    Well, I've checked in 3 places and each time drilled 3 holes 2 inches apart horizontally. Checking the depth with the wire, the stud location as found with the 3 methods (electric stud finder, magnetic stud finder, and by sound) is always 4 1/4" deep. Left and right of the stud is 6+" . So to simply say I missed the stud, I'm not convinced.
    – Erikstg74
    Feb 10, 2018 at 18:47
  • Maybe this will convince: the drywall is attached to something, somewhere ;-)
    – sribe
    Nov 27, 2022 at 19:25
