Water leak from above windows created bubbles. I stripped the damaged section with putty knife, did I go too far? What steps should I take next? I'm new at this, I think I'm supposed to add primer and then a coat of paint.
  • Ed's answer below and the Onetime(r) product will work. The big thing is the leak is no longer present that created the problem to begin with. – Jack Feb 3 '18 at 21:53
  • I just don't understand why normal primer (sealer) is not preferred in this situation since the whole wall was done this way? Still solving the leak problem. – Altoban Feb 4 '18 at 11:45
  • Yes, regular primer will work, please be certain the leak is gone and the wall is absolutely dry. – Jack Feb 4 '18 at 15:40
Here is the over kill but guaranteed way to fix this. There are steps you can skip, but the paint may crack/peel/bubble/not stick if you do. Water damaged gypsum board can be tricky.
Remove any loose material. Lightly sand. Apply Zinsser Gardz. Allow to dry and lightly sand. Patch/skim with spackle/mud. Allow to dry and lightly sand. Repeat application of spackle/mud and light sanding if necessary to achieve acceptable finish level. Apply Zinsser Gardz. Allow to dry and lightly sand. Finish with 2 coats of normal paint.
  • It can be hard to find the product or equivalent since I'm not based in US. but is this the same thing which I got? reddevil.com/index.php?l=product_detail&p=912 – Altoban Feb 3 '18 at 21:18
  • No, that's not the same thing. Look for a primer that will either repair damaged wallboard, fix peeling paint, allow painting after removing wallpaper, or prevents bubbles after skim coating. If I were you, I would buy Gardz on eBay from anyone who will ship internationally. – Dotes Feb 3 '18 at 21:37
  • I forgot to say my wall isn't drywall. – Altoban Feb 4 '18 at 8:28
Did you go too far? I don't think you did. It is best to remove the loose material. I would use some topping compound and fill the area and lightly sand. This will give a normal look. If you just prime and paint it will be visible for years. I use topping mud where I need a thin coat. It sands easier then prime and repaint and you will have a professional looking repair.
  • Never heard of topping mud before, what's it usually used for so I can know what to ask for? Btw this is not drywall. – Altoban Feb 3 '18 at 17:07
    Yes it looks like plaster, I would still use topping mud it is a softer lighter form of drywall mud. It is easier to put a thin coat down and easier to sand, anyplace that sells sheetrock / mud will have topping mud many places will have small tubs like a quart for a few $. – Ed Beal Feb 3 '18 at 17:13
  • I can find it if only I have a description people will understand since I'm in a non English country. – Altoban Feb 4 '18 at 11:29
  • This store here has the most products but don't know where it is: cmbegypt.com/cmbgroup/products/admixtures – Altoban Feb 4 '18 at 11:39
