Can I use pex from my shower valve to my tub drop ear elbow?
    Why don't you think you can do this? From everything I see right now, sure.
    – Hari
    Feb 3, 2018 at 0:18
Yes, you can. But there's an important caveat here. The other connectors are using Sharkbites, which are push connectors. The two in your picture are a compression fitting. You'll either want a crimp ring or a clamp ring to secure the pex to the fitting. These might require a special tool. You might also get away with using a regular screw clamp.
