I have a newly constructed home In the Northern Part of Ohio and am planning on working to finish my basement. The summers a warm and humid and the winters are quite cold and dry. I have a walkout basement and the grade is sloped significantly away from my foundation. I have not had any water issues, and my sump pump never runs. I know this question has been somewhat addressed before, but I can't find anything that specifically addresses my situation. I have that wall blanket installed on my foundation walls, but on parts of them, the blanket is only covering half of the wall. What should I do about finishing the bottom half? Here is a picture for reference.
basementwall
    Seems like step one in any insulation question is to provide some information about your location and climate. Please revise to do so. – isherwood Feb 2 '18 at 14:19
The blanket's providing almost nothing, so get rid of it (in that placement) and grind its fasteners down to flush with the wall. Research and testing has determined that a rigid board insulation (some sort of foam or rock wool, which requires a vapor barrier) tight against any exterior wall and those joist bays above the wall are the only way to go.
That way, you're minimizing and even eliminating any place for water vapor to collect and warming the exterior wall to avoid water vapor from condensing. Once that convection layer (no less than 1-inch thick) of rigid insulation is on or just rested into place, then the old fluffy insulations can go on top along with a stud wall.
Though, more rigid insulation is most beneficial. Any stud wall, in your non-load bearing situation, can then be comprised of as little as 1"x2" furring type members or regular dimensional lumber laid flat...to save floor space. And actually, you'll get the biggest benefit from insulating the ceiling. Being able to finally hold heat or cold in the room, may make you question whether to finish the walls or to just strip and repaint them...start with the ceiling, you'll be surprised and may be done a whole lot faster and easier (no new electrical requirements to satisfy).
| improve this answer | |
