Didn't see this question from my searches but I'm unsure if I have my terminology incorrect. I've been looking to add some finished, air controlled, rooms to a metal building with beams upon my research I've seen multiple ways to attach a wood frame on the inside:
from: 2x4 Wall Framing and Questions on Interior wall treatment that seems to place walls in between the beams and www.WilsonworksConstruction.com - Wall Framing (which is a bad video) so:
from: Frame up of New Office in metal building showing the framing from outside of the beam. If I plan to run electrical and insulation which process is correct and how would you properly fasten the wooden interior walls to the metal beams? Is there a special way to do this? I'm familiar with installing interior walls in a basement and to concrete floor with a Ramset Gun but I don't know if this is the same process.
