I have a Lennox MPD3530CNM-B fireplace. It is controlled by a standard toggle switch on the wall. I can turn on and off the fireplace even when there is no power. It looks like my fireplace uses a thermopile. As a result, the switch on the wall does not have electricity coming from the electricity panel. The switch on the wall is connected directly to the fireplace.
I am concerned with the fireplace. I understand the Lutron Maestro is an electronic switch. Based on my research, I am not going to be able to use a Digital Switch to operate the fire place.
- How do I replace a standard toggle switch with a Lutron Maestro 'Digital Switch'? If it is not possible, does anybody know if Lutron has a mechanical switch with look like Lutron Maestro and would do the job?
- If I ever replace successfully the switch to a Lutron Maestro, will I still be able to turn on and off the fireplace with the switch?
I am in the process of changing the standard toggle switches in my house for Lutron Maestro Digital Switch. My goal is to have Lutron dimmers, switches and wall plate to have a consistent look across the house. That's why I am trying to find a way to power on and off the fireplace with one a Lutron Maestro switch.
I would really appreciate if someone could help me figure out how this would work! Thank you!
