Can the Eaton PT18M-W-K (1800-Watt 15 Amp) timer be used for a 1500-Watt baseboard heater? According to the specs, the answer appears to be "yes". However, "heater" is conspicuously absent from the list of devices that can be connected to it.
Curious... why would a person use a timer as opposed to a thermostat? – isherwood Jan 30 '18 at 14:27
Is the baseboard heat operating on 120v or 240v? If you don’t know that, does the breaker have a single or double handle? I agree with Isherwood tho, use a thermostat instead. Perhaps you’re planning on using both, and the thermostat is already present? – Tyson Jan 30 '18 at 14:35
@Tyson 1500W is a common value for 125V heaters because they just fit on a 15A circuit. (Notice the part where they are 12*5* volt). – Harper - Reinstate Monica Jan 30 '18 at 18:15
@Harper many inductive baseboard heaters can be wired either way, the end user may make assumptions which is why I asked for clarification. – Tyson Jan 30 '18 at 18:17
The device is rated at 1800w or 1/4 HP motor loads so I would say it should be fine. I like to have a higher rating if possible but this is rated for halogen lighting. It's basically the same as a resistive load like the nichrome wire used as an element in most electric heaters.
1You need a higher rating for halogen lighting due to inrush current. It's crazy all the wattage certs you see on relays, one number for well-behaved resistor loads, another for "tungsten" that being yours, another for motor, another for HID lighting (due to the inductive kick on interruption of those big ballasts on 400/6000/1000W sodium lights). Electronic ballasts use the tungsten number because they have inrush. – Harper - Reinstate Monica Jan 30 '18 at 18:13
