My apartment has a balcony on the 4th floor of a building, which I covered with artificial turf to make it look nicer.
The problem is that the wind lifts up and folds the artificial turf all the time
To prevent this issue from happening, I have been thinking about the following solutions, and none seem adequate:
- Gardening iron line which I could pass through the turf holes (circled in red in above image) and attach to the balcony wooden boards, problem is that it wouldn't hold well to the boards (would probably slide out eventually)
- Tablecloth clip but I guess they will eventually rust (even those stainless ones aren't completely stainless)
- Custom-made wooden casing: covering the sides and holding the turf down. Seems like lots of work to setup and maintain (wood)
What would you use to stopping the wind from lifting up/folding the turf?
