I am planning on doing a major Reno to my main floor this year and am looking for guidance on how to do the flooring.
I currently have vinyl peel & stick tiles in the hallway and kitchen. This was applied over the original builders 12 x 12 faux marble tile (circa 1975). The L-shaped LR/DR is carpeted.
I want to install engineered hardwood in the LR/DR/hallway and ceramic in the kitchen. I will likely also be replacing kitchen cabinetry, in case that should be a consideration in my approach to this reno.
This project leaves me in need of advice regarding how to remove the old vinyl floor, and if I cut through the underlay to do that (which seems like the easiest way, though there is a possibility of asbestos in the builder’s tile) should I remove the underlay from the carpeted areas before laying the engineered hardwood.
I hope that makes sense. Thanks in advance for any advice offered.
  • Welcome, Jackie. Please know that we are not a discussion forum, and you're obligated to ask a more specific question. Please revise to make it clear what you're asking. See the help pages for more information. – isherwood Jan 27 '18 at 23:15
  • Not near enough info, please supply type of subfloor, how you intend to fasten the wood, (glue, float, staple down). What the vinyl attached to ( subfloor, underlayment), if underlayment then what kind. The variables involved in this is huge, and all job conditions vary. Pictures help also. – user81381 Feb 12 '18 at 16:10
