I am doing some remodel work in my finished attic. I've removed some drywall and have temporary access to the side attics. I'm concerned about the insulation and would like to fix any problems now before I install new drywall. The below image illustrates the current insulation status. There are roof vents in both the side attics and the ceiling attic. The pink lines indicate where there is insulation. In the side attics the insulation was peeled back from underneath the roof vents, so they are not covered. There are NOT any insulation baffles in the rafters connecting the side attic and ceiling attic.
Question 1: Should there be insulation baffles, or is it okay to not have them since warm air can vent through the vents in the side attic.
Question 2: Would it be better to remove the insulation from the rafters in the side attic and add insulation to the knee walls? This would have the benefit that I could fully insulate the knee walls. Currently, the insulation in the side attic rafters is incomplete since it is pulled back to expose the roof vents. I've added a second illustration to show what I mean.
