I am trying to add a new outlet off this box for my TV and I want to confirm that I am wiring this properly.
The outlet I am connecting to has one socket that is run off a switch. So currently the box has one white cable (with white, black, ground) coming in as well as one black cable (white, black, red, ground).
The bottom socket has constant power at this point, while the top is running off the switch.
Id like to connect a new outlet that also has constant power. Can I just pigtail my wires off the white wire coming in? Is there a better approach? Any additional information I can provide?
