I've got a cast iron radiator where the end with the bleeder valve is shoved up against a wall. Is there any other way to bleed a radiator? Supply and return pipes are at top and bottom of the opposite side. What if I loosened the nut on the top pipe?
    is this a steam or hot water system – d.george Jan 26 '18 at 18:10
