I am trying to fix a gap at the shower door frame which I think resutled from previous owner's improper installation/sealing.
As you can see, there is this little gap at the shower door frame. That orange stick was from the hole, part of the unsuccessful sealing attempt from the previous owner, I believe.
The gap is in a very hard to access spot and direct sealing would't fully fill it up. I am wondering if I could apply some waterproof sealing foams on it?
Would these products be the right one I am looking for? Are they waterproof enough to apply on shower door gaps, or it's just general waterproof that can't really be used in shower door frame.
https://www.homedepot.com/p/Loctite-12-fl-oz-Tite-Foam-Insulating-Foam-2045981/206310510
http://www.premierbuildingsolutions.net/product/xtrafoam-minimal-expanding-foam-sealant/
-1
Gap doesn't look that big. I would use silicone caulk.
