I have a Whirlpool Duet front loading washer. It finished its cycle, all the lights are off, no error codes, but the door won't unlock. I unplugged it and let it sit. Then I found a manual online that said to remove the toe panel and pull a manual release. I think I found it but the lock still won't open. I tried running through the diagnostic cycle and didn't get any error codes and it makes the usual sound it makes when it locks and unlocks. Any other ideas? I belive it's one of these 2 models: GHW9100L or GHW9200L
  • There may be a problem with water drainage. Take a look at this: https://homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html – dev1998 Dec 21 '18 at 19:14
After letting it sit overnight unplugged, the manual release worked. Problem solved...now on to figuring out what's wrong with it.
    Thanks for letting us know what fixed the immediate problem. Please be sure to give yourself a check mark for the answer so others will be able to find out how to unlock theirs. – FreeMan Aug 13 '20 at 16:41
