My hot water tank went and I'm trying to replace it with a tankless system, but the old water heater did not have an expansion tank installed with it.
In my previous house I had a combination unit with only 1 expansion tank, so I'm assuming there must be some sort of set up where by 1 tank can buffer against both expansion in the baseboard heat as well as the potable hot water system.
My boiler has a backflow preventer upstream of a 8.5 Bar auto fill valve which is upstream of an expansion tank.
  • Do these need to be in this order?
  • Can I put the autofill and expansion tank upstream of back flow preventer and thereby 'T' off of it and use the line for my ondemand water heater as well?
I cannot see why an expansion tank would be required with a tankless waterheater. The heater only comes on when a valve is opened and water is flowing through the tankless heater and the pipes. When all the valves are shut the tankless heater turns off. The hot water trapped (marooned in the hot water lines) cools and contracts. The heated water pipes also contract and there would only be an increase in pressure if the volume of the pipes decreased more than the decrease in volume of the trapped water. I don't believe it does and anyway the volume in the pipes is so small that any pressure increase in the pipes would be negligible.
Pressure increase in the water system of a residence with a hot water tank occurs because when hot water is used the water in the tank is replaced with cold water which continues to be heated after the valves are turned off. This large volume of cold water expands significantly as it is heated from cold to about 140 F. If the residence has a backflow prevent valve, then the increased volume of the now trapped water leads to an increase in pressure to the point that pipes or fixtures can be damaged. But if the residence does not have a backflow prevent valve, then the pressure in the house will not rise but will simply stay at the pressure of the water main.
Addition in editing
In another thread on this site someone made the statement that most or all city water meter "yokes" have a simple check valve to prevent backflow. I have not tried to confirm this for Dallas TX where I live. This would mean that all residences with a hot water tank could benefit from having an expansion tank, but AFIK expansion tanks are not used in Dallas. We had tank water heaters for 30 years and noticed no sign of pressure build-up. However, water pressure at the meter here in Dallas is relatively low, I think about 50 psi.
If your baseboard heat is tied into your potable hot water, you should probably be okay with just one tank. Having said that, your baseboard heat should be essentially a closed system, so it shouldn't be affecting your potable water.
You should have an expansion tank on your potable water system. That tank also functions to cushion the water hammer effect that would otherwise result from your washing machine or dishwasher every time they turned off their internal valves. Not having that tank will cause appliances to fail more rapidly.
    I would expect that modern clothes and dish washers would have "soft close" valves which would not produce water hammer. In any case, I don't detect any water hammer in our house and we have no expansion tank or water hammer arresters. Jan 21, 2018 at 2:39
  • Thank you for your attempted answer. After a ton more research, it turns out the answer @JimStewart gave is correct. Moreover, even if i had a 'tank type' water heater, the fact that that my city doesn't require / I don't have a check valve on the supply line means that water can back-flow into the city main to reduce pressure.
    – virtualxtc
    Apr 23, 2018 at 20:24
