We have an outdoor faucet on the side of the house with a shutoff valve that no longer appears functional. (Thankfully, the house's main water valve does shut off water, but many other valves appear to not shut water off at all or at least not completely.) Obviously this needs plumbing, but for various reasons that might come later rather than sooner, and I wonder what can be done about that outdoor faucet in the mean time.
I'm shocked it has not frozen already, given continuously below freezing temps here in the northern stretches of northeast USA. When we open the outdoor faucet, water pours out with full force whether or not the indoor shutoff valve is cranked as far closed as it will go.
The simplest solution to ease our nerves about this pipe freezing in the mean time seems to be letting the outdoor faucet run a little bit - a very slight stream / steady drips - until we fix this or temperatures rise. Steadily pouring water a couple of feet from the side of the house seems like an iffy idea to me though, at least if doing it for more than a few days (I may be talking 2-4 weeks.) Is it OK to let an outdoor faucet drip overwinter to prevent freezing when the pipe can't be shutoff from indoors?
Faucet pops out of cedar siding above rim joists, a couple feet above ground level. Below the faucet's pipe is a basement with painted concrete floor & walls. I'm weighing risk-benefit to some extent, because even if this particular pipe froze, that might not be too disastrous. Then again, maybe it has ripple effects I'm not considering.
