I have several 2"x4" x 12ft pieces of wood that I will use as rails. I need to secure them to several 1/4" steel plates. The steel plates have two holes for screws ( or whatever I end up using). The wood doesn't have holes and I don't want the screw to go completely through the wood.
What's the best way to secure the 2x4 to these plates?
Thanks.
  • It's not at all clear what you're asking. What specifically is the problem you face? With no idea what you're building, what can we say?
    Jan 16, 2018 at 2:15
  • Yes we need more details and possibly some design drawings.
    – Paul Logan
    Jan 16, 2018 at 5:14
So I'd use something like a bradawl to mark the positions then drill a pilot hole if necessary (depends on wood, position of hole, diameter of screw etc)
See How can I drill to an exact depth with a hand drill?
That's just a matter of buying the right sized screw.
