The pressure gauge connected to my well water tank is dripping very slowly. Maybe few drops per day. I am guessing this based on the accumulated water in the container underneath. It seems that liquid is overflowing from top of the pressure gauge. At the top, there is a hole, function of which is not clear to me. Could someone tell me why there is hole at the top? And why water is coming from the top. It could be total coincidence but I observed this first time when outside temperature became very cold below -5˚F last week, and it’s dripping since. Is this something I can change myself or should I call a plumber? And how soon I should fix it. Thank you.
1 Answer
The hole is to provide atmospheric pressure inside as a reference for the gauge. That is, the pressure indicated is relative to ambient pressure. Or, in other words, the gauge indicates how much more pressure there is inside the pipe than outside the gauge.
If the gauge is leaking through the air vent, it is time to replace the gauge. The internal mechanism has failed, probably by rusting through or otherwise breached the pressure-sensing diaphragm.
Freezing conditions could well stress the gauge possibly due to a little ice build up.
Yes, this is something most anyone can do. Turn off the pump and relieve the pressure in the line (open a faucet). Using a wrench, vicegrip, or similar tool, unscrew the gauge assembly (gauge plus its short input pipe). Using the tool, grasp the gauge's pipe which comes out below it. There should be a four- or six-sided grip (turn it counter-clockwise as seen from above.
If it has been installed for a long time (years), it will be reluctant to turn at first. A longer handled tool will provide more torque, but take care to provide counter-torque to the pipe it is screwed into to prevent damaging other parts of the plumbing. (Provide counter-torque with another wrench or tool attached to the plumbing near where the gauge is screwed into. If the wrenches are about 90° relative to each other, it is convenient and efficient to twist them opposite to each other so that the water pipe experiences greatly lessened torque.)
Once you have the old gauge assembly out, take it to the parts store for a suitable replacement. Consider using a fine wire brush to clean the seat (the threaded hole the gauge is screwed into); Teflon tape makes it easier to insert the new gauge.
I wouldn't wait long; do it in the next few days. It will leak more and more the longer you wait.
1Wow! Very detailed answer. I do appreciate. I am impressed. I am doing tomorrow myself. Thanks. Jan 12, 2018 at 12:17
1Most gauges in my experience have a 4 sided rather than 6 sided grip surface, otherwise right on. Seems very likely to be freeze damage in this case.– EcnerwalJan 12, 2018 at 14:59
@Ecnerwal: Looking at a variety of them, it looks like more are six than four, but I have adjusted my answer accordingly.– wallykJan 12, 2018 at 17:45
I agree with the answer , but @Ecnerwal is correct most all bordon tube pressure gauges are 4 sided weather they are glycerine filled or not. The glycerine is to dampen the needle movement while the pump is running.– Ed BealJan 12, 2018 at 18:03
