Background: I am a regular DIYer just starting out. My question is regarding the ground wire while installing a chandelier. I have just moved to a new location in Ontario, Canada. The house was built in 1999.
This is a picture of the previous installation of the fixture onto the junction box.
Observation: The ground coming out of the previous fixture was connected to the green nut on the bracket. However, in the pic above, the ground from the supply is visible in the junction box but isn't connected to the green nut.
I installed the chandelier the same way. It works.
Concerns:
Is it safe to assume that the installation is safely grounded because the fixture ground wire is connected to the green nut on the bracket which in turn is connected to a grounded junction box?
If the junction box is indeed grounded, is it normal for the ground wire to be visible in such a manner?
If the junction box isn't grounded, should I pull down that ground, connect it to the fixture's ground and then connect an external copper piece to the other 2 grounds and finally the external ground to the green nut? Research indicates that the green nut has place for just 1 wire.
Thanks for reading.
