I have four lights in my new house that each have two different switches to control them. They are wired so that one of the switches would have to be ON and the other OFF for the light to be ON. If both are ON or OFF, the light would be OFF.
The power went off a couple of months ago for a couple of hours. I now have 3 lights that the double-switch now works the opposite of how it used to work. Now if both switches are ON or both OFF, the light will be ON.
I tried turning off the power to the house when the switchers were all in the OFF positions but when I turned the power off, the lights went back to being ON. I then tried changing one of the switches to ON position and turned the power off and on again but the light remembered the state it was in and stayed the same.
I'm not sure what else I could do. How can I reset them to work like they did before - so that OFF + OFF = OFF?
Here are pictures of one of the switches. I thought they were normal switches and there was some other sort of switch that controls the light but it does look like there are two white leads and one black to each switch.
