I have a oil (converted to natural gas) hot water boiler running three zones of baseboard heat. Lately I have been hearing water rushing through one of my zones (I don't hear it on the other zones). Additionally the boiler pressure is 20 psi. From research it should be about 12psi. I opened the spigot on the affected zone and drained about 4 gallons of water until it flowed freely without spitting. The pressure went down to 10-12psi. However as soon as I shut the spigot, the pressure climbed again back to 20psi. I can still hear washing rushing through the pipes but could that be just refilling?
What should my next step be? Should I drain more water on the zone or is there another valve that needs opening? Here are pictures of my system. You can see the hose on the spigot I opened.
UPDATE: Following the comments below, I reduced the pressure on the fill valve which reduced the boiler to 15 psi. I will wait to see if I hear the water rushing through the pipes.
UPDATE: Water still rushing through pipes.
bleed spigot on affected zone
whole system
right side of system
  • Back off the pressure on the fill valve. Upper right above the pressure tank, right after the Watts 9-D. It may need to be replaced. – Paul Logan Jan 6 '18 at 18:43
  • @PaulLogan I know what you mean by the watts 9D? – salisboss Jan 6 '18 at 18:52
  • @PaulLogan I found the fill valve but I don't know how to reduce the pressure. – salisboss Jan 6 '18 at 19:14
  • It is a watts T1156F valve. – salisboss Jan 6 '18 at 19:17
  • You also need to bleed from the highest billed valve in the zone. If this zone is upstairs it will be on that floor. – Tyson Jan 6 '18 at 19:41
