I’m having carpet installed in a few days, so I’m going through and pulling up the carpet and pad to put in deck screws in the subfloor plywood where there are squeaks. So far going well, but there is one area where I can’t figure out how to stop the squeak for the life of me. It’s in a corner, between the entrance to the master bedroom and the entrance to the laundry room.
In the pic, at the bottom you can see arrows where the last known joist is; it runs left to right. Then there is a run of over 32” till the next joist, at the master entryway (where green and red pad meet). There are nails in the subfloor from the builder at 16” from the joist, but they don’t go into a joist, as I confirmed with several pilot holes (seen in pic with X). In fact, I drilled a hole every 3” between the last joist and the entryway trying to find a joist, but to no avail.
I drew an outline in the pic of where I can step and hear the squeak. There is a circle with “center” which is where the squeak is the loudest. I’ve placed screws in the master entryway joist, and at the corners near the walls, but no luck.
Any ideas on things to try? I’m really confused, and the abscence of a joist where the nails are has me puzzled. Normally the joists are spaced 24” apart in the area below where this pic is taken.
    if you drill a hole every 3", it is possible that you can miss the joist. or the joist runs at a different angle .... poke a curved coat hanger wire down the drilled holes and spin it around so that the tip of the wire moves in a wide circle under the floor. if there is a joist, you will hit it ... also you could try using a stud finder ... or drill a bigger hole and use an inspection camera
    – jsotola
    Jan 3, 2018 at 6:22
  • I did every 3” because the joists are laid down flat (ie 3.5” wide), and at least in the 4ft before this area, the joists are running left to right. But that’s a great idea with the wire hanger, I’ll give that a try and see if I can find it. I had tried using my little Ryobi stud finder, but I think it’s too weak with the 3/4” plywood (and it’s not great to begin with)
    – Michael
    Jan 3, 2018 at 12:48
  • 32" is more than the subfloor is rated for. There must be another one in there. That said, the squeak may be a nail through the bottom wall plate. Try shimming under the plate near the doorways and see if it changes anything.
    Jan 3, 2018 at 16:21
Two long for a comment, Fully agree with shims and glue. I wish they had Gorilla glue when I was building, that stuff works really well as it expands and then gets hard so for some areas that's all that may be needed. The wood needs to be dampened with water first for gorilla glue to work. I have used it on a 2 story home the owner did not want to open the first floor ceiling. I drilled through the floor in several places above the joists dribbled a few drops of water in the holes and once the water soaked in filled with glue, after the glue was dry I cut the tops of the holes where the glue expansion bubbled up. Worked great but you will need to find the joists. There should be a joists because 24" would be the max spacing. My only other guess would be a change in direction of the joists.
If you can figure the thickness of the subfloor, set a circular saw to that depth just enough to cut all the way through. Cut the subfloor out, keeping 6" away more or less, from the 2 walls. Remove the plywood, this will let you see what you need to see. Sometimes the framing changes direction and that can cause squeaks in the framing itself, sometimes it will squeak in the framing without the direction change. Shim and/or refasten as needed. enter image description here
  • Interesting idea. I do know it's 3/4" subfloor (had to replace a damaged piece with a hole in the master bedroom). From your picture, if I don't find joists, you recommend placing two 2x4 blocks between the joists? Would I need to put support angle 2x4's underneath the blocks, like the normal joist framing is?
    – Michael
    Jan 3, 2018 at 18:46
    The hole will give you access to see what can be done with the framing under the subfloor. The 2x4 blocks, whether you use 2 or 3, depending on the conditions, will simply reinforce the joint where the plywood was taken out, so you can reuse it. Whether you can add more structure to help carry the floor in that area depends solely on what you find once you cut the floor open. I am not expecting you to find anything that would be of value so far, to underpin this framing to reinforce the floor in that area. Only perhaps a space where some glue could be inserted or shims with glue.
    – Jack
    Jan 3, 2018 at 22:00
