It has been announced that we will be getting smart meters installed in our city by our electrical utility (in the US) later this year (2018). A bank of 23 analog electrical meters now sits about halfway down the hallway (inside our building)from my ground story apartment. I have been hearing for years how RF radiation from smart meters is dangerous to our health. Are they really as dangerous as they are made out to be? And if so, what can I do about it?
  • I am not sure how there could be 23 meters code limits each feed to 6. The RF energy is less than a cell phone, there are some folks that think 60hz 120v is hazardous. If you are concerned a simple faraday shield will block the RF, this can be made from chicken wire or other metal/ foil mesh that is grounded. – Ed Beal Jan 3 '18 at 9:39
  • what organizations are making them out to be dangerous? It's a cell phone that makes sporadic calls to report usage. Furthermore, most non-smart meters made in the last 20 years also have such cellular devices inside; they don't have the same digital real-time circuitry, but the cell-phone radiation they emit is the same (or higher) than smart meters. who benefits from such fear-mongering? – dandavis Jan 3 '18 at 16:33
  • Ed Beal..I have spoken to our local utility since I posted my question. They will not allow a faraday cage to be mounted on my meter because it will block the transmission of signals from the meter. But she did say that I could have my condo repainted with “EMF paint“ that could help block harmful emissions from the smart meters. I will have to look into that. I did not mention that my building was built in 1977. Perhaps the code was more liberal about how many meters could be attached to each feed back then. Nor was I aware that code now restricts each feed to 6 meters in new construction. – MJCallinall Jan 7 '18 at 20:35
  • @EdBeal -- on large multi-meter installs, there will be a whole-building service disconnect upstream of the meters – ThreePhaseEel Apr 28 '18 at 13:19
  • Code limits the disconnecting means at each location to 6 I don't know how they could go beyond this limit as it has been code since I can remember, a grounded mesh on the opposite side of the wall will attenuate the EM field behind the meters if you are concerened, the meter dosent need to be fully enclosed to block EM radiation. A metal screen like for a door can be attached to a wall and grounded this will reduce any signal to a very small level and may not be measurable without very high end equipment. The paint can work but not as well as a metal shield (dosent need to enclose the meter) – Ed Beal Apr 28 '18 at 18:15
No.
It's a cellphone radio, of which there are probably another 3+ in your home.
It's also got a switchmode power supply, which there are probably 20+ of in your home.
    the ones in out area don't even use cell phone technology. they somehow communicate over the powerlines – jsotola Jan 3 '18 at 6:07
  • Actually, they may use a regular internet connection (dialup phone or DSL or cable or FIOS). Whatever connection they use (wired or wireless), if the utility is smart they will have one meter acting as Master and doing all the communication will all the others slaved via Modbus or a similar connection. – manassehkatz-Moving 2 Codidact Apr 29 '18 at 3:09
There are people who will claim that anything with a radio transmitter is dangerous to your health. Usually without any real evidence.
The meters will be built to comply with the radio transmitter safety standards in your country, just like the mobile phones, WiFi home routers and all the other wireless gadgets that our homes are filled with these days.
