I have a Lennox Merit series gas furnace ML193UH in my attic. The furnace turns on, but no air blows out of it. So i figured the filter needs to be changed. But I'm not able to find it. The pictures show the furnace i have. I have changed the filter for the main air intake vent. Any thoughts on where the furnace filter is??? Thanks!
  • Open the clips on the left side of the last picture. I can't tell for sure in the picture but that looks like a filter holding return vent.
    – Tyson
    Jan 1 '18 at 19:47
If you have a filter in the return air grille, that's likely the only one in this system. Nobody wants to climb into their attic just to replace an HVAC filter, so when a furnace or air handler is installed in the attic these filter grilles allow placement of the filter in a more accessible location. In fact, according to page 6 of this spec sheet for that model furnace, a filter rack is not built into this model and is available as an optional accessory.
So unfortunately, something else is wrong with your furnace...
    Thanks! I'm seeing red light blinking frequency of 3 times which seems to indicate there is an issue with the pressure switch.
    – Jaimin
    Jan 2 '18 at 20:23
