I’m moving into a my new home and fixing things that I can. Does anyone know what kind of light bulb I need for this ceiling fan light ? My best guess is a T4 based on googling but the slot has a meta connector in each side. It also reads 500w
enter image description hereenter image description here
  • FYI I believe there are now LED's to fit those old halogen fixtures.
    – agentp
    Dec 29, 2017 at 20:16
  • Yes they do make led's in the R7S style. I am not sure if they go up to 500w equivelent but I have purchased some 300 equivelent for work lights waiting to see how they hold up on portable lamps.
    Dec 31, 2017 at 20:19
I believe this is a 118mm j-type long / r7s base halogen lamp they do come in 500w , but also smaller 300,150,100 & 50w. When installing a halogen use the packing material or a clean tissue to hold the lamp. Finger oils cause the lamp to overheat and sometimes explode.
  • Thank you so much ed. I’ll give this a try and this gives me a great starting point. Dec 31, 2017 at 17:38
