So i was cutting wood and noticed the shaft was slipping on the blade. So i took off the blade and put it back on making sure it was tight and it stalled so i loosened the bolt a little bit it stalled less then i loosened it more and it started slipping again i don't know what it could be.
(I have a craftsman 5 1/2 inch 4/5 hp circular saw #H9179 and it is one of the older corded models)
Thank You
.... and one of the older corded models
...... what do you meanand
? are you talking about two saws? – jsotola Dec 29 '17 at 3:36
