I am setting up christmas lights. I have two shrubs which are about 6 feet apart, and I want to put an LED string set on each. I bought a two-prong outdoor extension cord to run between the shrubs.
The prongs from the extension cord do not fit into the end of the LED string. However the LED prongs can plug into the other side of the extension cord without issue.
Do you need some sort of converter to allow the prongs of the extension cord to go into the xmas light string set?
Thanks
This is the extension cord prong end:
This is the LED string light end:
The packaging of the extension cord says it is polarized.
