I have a utility sink with metal legs which was never anchored when installed and would like to anchor it to the cement floor. Don't want to go to the expense of using Tapcon screws. Thanks for your help.
  • 5
    Your question is unclear. What's your budget if not $6? – isherwood Dec 19 '17 at 14:40
  • 6
    A box of 8 tapcons is $2.75, another option is a box of plastic anchors which will be minimally less. My sink legs are not anchored to the floor but my sink is anchored to the wall. Less work to anchor the sink to the studs than to drill into the concrete. – Platinum Goose Dec 19 '17 at 15:49
  • Maybe not having a proper drill is part of the expense of the otherwise cheap tapcon? But if you don't have a drill, you're limited to... adhesive, I guess? – JPhi1618 Dec 19 '17 at 16:10
  • You can use masonry nails without a drill. It risks chipping the floor and makes removing the sink overly difficult though. – Matthew Gauthier Dec 19 '17 at 19:29
    Masonry nails are not going to do well unless the concrete is fairly new. It takes a big blow with a big hammer to drive them into aged concrete, and an unacceptable level of damage is likely. – isherwood Dec 19 '17 at 19:49
Get good light to the area. Make sure floor is very clean and dry. Buy one tube of 100% clear silicone caulk with gun. Lift each leg individually, stick the tip of the calk tube under the foot and dispense a liberal dose of the calk product directly between the foot and the floor. Let foot rest in puddle. Repeat for all four legs. Do not disturb for 24-hours.
|improve this answer|||||
    Not a bad option, but the foot on those sinks is small enough, and silicone is soft enough, that a few accidental kicks of the leg is likely to break them loose. I'd probably use construction adhesive. – isherwood Dec 19 '17 at 19:48
