I've got a brand new single pole GE 14294 Z-Wave Plus dimmer. Before I try to connect it to z-wave, I wanted to make sure it was working. I have five LED lights (4W, 65mA, BR20 flood) lights in series. They were dimming fine on my old Leviton dimmer so I know they are OK.
Using the switch itself, the dimmer will switch the lights on and off no problem, but will not dim. BUT, if I unscrew two bulbs, then the remaining three work fine - i.e., the dimmer works correctly. If I add the 4th back in, the will dim slightly.
I've checked the current, and 3 lights are pulling about 0.2A. With four that goes up to 0.26A, with five about 0.32A. Switch is rated for 1500W and is compatible with LED.
I've tried a different 14294 and have exactly the same problem. Note that at this stage I'm just using the physical switch, so nothing to do with z-wave.
Any ideas? Bug in the firmware? Could it be the bulbs? I Called Jasco/GE and they didn't know.
  • What make and model are the bulbs? Dec 14, 2017 at 4:21
  • What is the power factor of the bulbs? Dec 14, 2017 at 8:16
  • Screw one incandescent bulb in (with 4 LED bulbs) and test. What happens? Also you probably don’t mean “in series”, if they are in fact in a series circuit fix that first.
    – Tyson
    Dec 14, 2017 at 11:09
  • @Tyson - correct - my bad. Not in series. Dec 14, 2017 at 14:10
  • @Harper - will measure and let you know. Dec 14, 2017 at 14:11
-1
I think this has todo with minimum load. These dimmers require 50 watt min
    Hello, and welcome to Stack Exchange. You should improve this answer because as it stands it is being flagged as low quality and is in danger of being deleted. I would suggest as a minimum if you could support the claim of the minimum load by taking a snapshot of the spec sheet for the switch that shows this data and explain what that means.
    – Michael Karas
    Nov 1, 2018 at 10:06
  • And, if this is true, then why do things start going wrong when the OP adds load to a working system? Nov 1, 2018 at 14:30
-1
I’m having similar issues, and looked in page one of the manual and it says for incandescent lighting only. Not impressed!
  • Hello, and welcome to Home Improvement. Good answer, but is this the same model as the OP? Would you elaborate a bit? Mar 7, 2019 at 11:20
  • Based on the manual available online @ zwave.eu for the GE 14294, this doesn't seem to be correct. It says "Compatible with all incandescent and most dimmable CFL/LED bulbs".
    – Khrrck
    Mar 31, 2020 at 17:42
