I have this kitchen sink mixer tap, which is leaking from where the neck meets the main body, whenever it's turned on, (either hot or cold).
So what I'm trying to do is remove the neck so that I can get at the inside, to possibly replace an O-ring or something. However, I can't seem to find any way of removing it.
I found a small screw at the back, which I removed, however this didn't make any difference. The neck can swivel around 360 degrees no problem, but when I tried to wiggle it or pull it loose (as described by many online tutorials), it wouldn't budge.
Are there any other things that might need to be done to take this off?
