We have 13 1.5" round steel tubes that go around a small area in our backyard Each tube has a small hole that crosses the tube. I'm including the basic design:
I would like to use wire rope (or steel cable) to go around all these tubes, and make a rudimentary fence.
What would I need? The tubes are galvanized, but I wouldn't want water to go inside the tube.
Thanks.
These are the regular tubes: enter image description here
This is the regular wire: enter image description here
10
  • How strong does the fence need to be? Dec 12, 2017 at 15:49
  • The tubes are solid since they're inside concrete. The fence should be strong.
    – rbhat
    Dec 12, 2017 at 15:52
    Strong enough to withstand a light breeze? Strong enough to keep in a dog? Strong enough to keep a hungry bear out while a litter of piglets squeals inside? Please at least minimally quantify "strong". Dec 12, 2017 at 16:35
    You say the pipes already have a hole in them. What details are you looking for other than "Run the cable through the holes in the pipes and put a metal cap on each pipe to keep put water"?
    – JPhi1618
    Dec 12, 2017 at 18:50
    @rbhat Look for videos on "How to Attach Wire Rope to Turnbuckles". Dec 18, 2017 at 9:59
The chain link fence folks have all kinds of fence post caps that could be used to keep the rain out. Also there are nylon caps for EMT. You could convert the tubing to iron pipe threads and install threaded PVC caps. As to the holes and lacing the cable, before installing poles, I would put them on the drill press and pre-drill.
  • You can also use some outdoor rated silicon caulk to help plug the holes the wires go through, after the wire are installed. Dec 13, 2017 at 18:44
There are many methods of attaching cables together in the manner that you are pursuing.
One option attach two ends of cables via a screw type connector:
Screw Cable Connector
Another option requires a crimping tool where the coupler is compressed around the cable ends.
crimping cable connectors
More information about other methods of connecting cables to posts can be found when researching "Cable Rail Systems".
A simple fence post cap and a little bit of silicone caulking would keep the water out of the post. These are fairly cheap at your local home improvement or fencing supply company.
Fence Post Cap
