ok...so...I am undecided what to use to power up this detached shed, which is 70 feet away from the main panel. I obviously want to go the safest route (shed is 200 square feet) Before hand, I really want to go the 30amp route, due to its cost friendly ways and I dont think I am going to use that much power; just want some opinions.
route 1 -
Use a double pole 60amp with #6-3 UF wire to feed a 60amp sub panel in the detached shed? (wire will be buried)
route 2 -
use a double pole 30amp 10-3 wire UF rated to feed a 50 or 60amp sub panel in the detached shed and use pvc conduit for the wire (or does NEC only allow direct burial with no conduit for UF wire?
what I plan on using in the shed - 3 security cameras 5 outlets (GFCI) power tools such as table saws and vacuums small TV and leave batteries charging
thats about it....
what is the best route?
