I am getting so many different answers on what to run to my detached shed. I am going to pull permits soon and have it inspected before hand - but im trying to blend in the codes for what it is allowed in Colorado
So, I am building a 200 sqft shed that will power up around 5 or 6 outlets along with 3 security cameras, power tools such as table saws, circular saws, battery chargers etc.
ive been told to use a double pole 30 amp with UF 10-3 wire to feed my sub-panel (which will be 70 amp sub panel) The sub panel is going to have 2 x 15 amp circuits and 1 x 20 amp circuit for my tools.
I also been told to run a 70 amp with number URD #4 cable (4 wire) to feed the 70 amp sub panel. I am not sure if thats overkill, or if that will give out TOO much power to my 70amp sub panel and if that will be too dangerous?
So, my shed will be about 70 feet from my main panel, so I will have to dig a trench. I was also told not to use a conduit (pvc pipe) for the UF rated wire - instead it will be bare burial. is that code?
