What diameter should pipes from boiler to heating the hot water cylinder be - the same as the pipes used for radiators or larger ?
The usual diameter is 22mm in the UK.
Radiators will be 15mm (or microbore which is smaller)
    Why are they different, what is the effect if you used 15mm for hot water, or conversely 22mm for radiators Dec 3, 2017 at 23:18
  • I surmise 15mm would either be insufficient to bring the cylinder contents to 60C or would take too long to do so. Upstairs rads are usually parallel to downstairs rads. 2 x 15 cross-reference area (2 x 177) is close to 1 x 22 cross section area (1 x 380)? Dec 4, 2017 at 11:42
  • Thanks, so larger the pipe the quicker in theory the hot water can get to where it needs to go (be it radiators or heating hot water cylinder) , but the downside is that boilers need to heat a greater volume of water to get sufficient hot water for all radiators, and also does the pump need to do more work to pump the water around ? Dec 4, 2017 at 13:18
  • My radiators downstairs are physically parallel to radiators upstairs, but each has their own supply/return loop they are not plumbed in series with the one upstairs. I don't get your point, does it matter where they physically connect to the 22mmm pipe (via 15mm pipe) Dec 4, 2017 at 13:21
