I have a range that I am hooking up, there is a red wire, black wire, copper wire and a white wire, I am asking if the white wire is a common wire or is it ground?
    White is neutral, bare copper is ground
    – Tyson
    Dec 2 '17 at 18:41
    White is never ground. Green, green/yellow or bare is the global standard for ground, it is the only standard color worldwide. Even Russia. Dec 2 '17 at 18:52
White is neutral, green is ground
White is the neutral (return). Green is ground (safety). Think of it this way: white is the normal way for power to return (like a drain pipe). Green is the safety (floor drain) that deals with spills.
