The only shower drain available at my local hardware store is The Wondercap, which looks fine.
However, the (white) plastic is formed with "ABS
", and the drain pipe itself is white plastic, which I assume to be PVC.
(Isn't ABS supposed to be colored black?)
Is there a safe way to bond these two pieces together? Or should I go find a real plumbing shop and buy a different drain, made out of PVC?
