thanks in advance for the help!
I am attempting to install a dimmer switch to solely operate the light on my ceiling fan light fixture. I have read that installing a dimmer for the fan is dangerous, however I have been told that having the dimmer only control the light, not the fan and the light, is okay. Correct me if I've been told wrong!
Before I attempted to install the dimmer, there was one switch on the wall that controlled the light and the fan was operated by the pull cord attached to the fixture. This is what I continue to achieve after I have installed the dimmer switch for the light. In the switch box there were 2 black wires, 1 red wire, and the ground wire. On the switch, the black wires were attached to 2 brass screws, the ground wire attached to a blackish-green colored screw, and the red wire was inserted into a small whole in the back of the switch labeled a "push wire".
On the dimmer switch that I bought, there is a ground wire, a red wire, a black wire (and a red/white striped wire, which the instructions said to cap as it could be used for 3 way switch, which I don't think I need for this job.)
I have left the red/white striped wire capped, as instructed. My ground wires are connected. And the 2 black wires from my wall are connected to the black and red wires on the dimmer switch box. And I have capped the red wire from the wall. This combination controls the light appropriately, however the fan is not working at all.
From this combination, I have deduced that the red wire controls the fan. Is the "push wire" hole on the original switch just a constant source of power and is not operated by the switch?
When I had red to red connected, with the 2 black wires from the wall connected to the black wire on the dimmer, the dimmer switch controlled the fan motor and the light did not even turn on. When I capped one or the other black wires from the wall, the dimmer still controlled the fan motor, or the whole fixture did not work, if I am remembering correctly.
So my question is, is there a way to wire the dimmer switch to have it solely operate the light and have the fan be controlled by the pull cord with the dimmer switch that I have already purchased? Do I need to buy a different type of dimmer switch? Or should I scrap the idea of having ambiance in my living room from my ceiling and invest in some lamps?!
The dimmer switch that I bought is a Lutron C-L Dimmer.
Lastly, I've also noticed a buzzing sound when the light is on. Is there a way to fix this? FYI, I've been keeping the light off to avoid something bad (fire) happening.
Thank you all for the help and suggestions!
